XXX and a JBL 1200.1, How do i wire them together?
  • 2
Big-Cat
Registered User
1,400
Jupiter, FL
OK, i've got my sub on it's way here, how do i wire a JBL 1200.1 to a XXX 12, and also the box will be ported and i going to need a crossover, or i dunno, it's some kind of filter that the 1200.1 doesn't have. I don't really know i just remember hearing someone say something about some filter that a 1200.1 doesn't have that it needs for boxes tuned low
they were reffering to a Subsonic Filter.
you can buy them seperate, im not 100 percent sure who makes one of how to hook it up..
anyways, to your wiring question...
they are a quad coil driver...
1 ohm? i dont know if its a 1 ohm driver
you would want eitehr 1 ohm or 2 ohm operationfrom taht amp..
assuming tis a quad 1 ohm driver, wire parallel series to your amp, giving it a 1 ohm load -
wire the positive and hte negative of 2 coils togetehr,
like - to + on two of the coils,
then on the otehr two, wire them pos. to pos. and neg to neg...
then the wires from the pos - pos go to the amps pos. and the neg - neg wire goes to the amps bneg.
i beleive it says they're like 1.17 ohms...or that's what it says on the website, but i'm guessing that would be ok either way, right?
do i need a subsonic filter because i remember seeing someone say it would like tear my sub apart? or should i just not worry about it?
Thanks for the instructions, you've helped out a lot
Ya, consider the impedance of the VC's to be essential 1 ohm...
go with a SSF.. they keep frequencies significantly below the tuning frequency of the box from being played..
this can cause serious driver damage...
if you ahve your box tuned fairly low (very close to the low end of your drivers Freq. response) dont worry, but in other applications, you should ahve one
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Big-Cat
Registered User
Big-Cat
Jupiter, FL
Wonderbread
    Jun 1, 2024
    May 31, 2024
