XXX 15" or MT 15" ?
the XXX is very loud with the 1000 watts im givin it..i think my ears are starting to go... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif and it sounds really clean...
ive used a xxx15 for a year and now have mt parts in an ubewoofer......in the same box with the mt is definitly louder will sacrificing a lil SQ around 50Hz and up.....the xxx (in this box, if i tune way lower to like 25Hz it aparently murders lows)..... with that much power id go with a xxx, if they can take daily a bit better with that kind of power..... cause to get the most out of the mt youll wanna add more power and before you knwo it youll clip the shit out of your amp...and subs dont liek clipped amps.....
XXX ftw. It will do better with 1500 watts, even though you should give it 2000 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif If you get another amp, MT for sure
I already sealed a deal for a MT15. Ill use my current amp for about a week or 2 untill i can get another tx1505 then ill be running one per coil. This should be enough power to make it happy.
Do you know how to gain match the amps, if you don't gain match them you may have a little problem with your sub like friing it. If not you will need a o-scope or a dmm to set the gains the exsact same. If you need to know how just pm me or ask on here.
ZeroGuage
ZeroGuage
Sandusky, ohio
ngsm13
