Sold Xtant 403a amp NEW never used
groov2
Here I have what is considered the cream of the crop in amplifiers. This amp is absolutely beautiful. There are some light scratches on the surface that can easily be buffed out. I can do this myself, but I want this gone asap so I can finish off my system.
I desperately want to use this, but I have an old school show winning stereo system that needs some revamping and the only amps it deserves are..you betcha, old school amps.
I can't stop thinking about how stunning this amp is. I would like to start the price at $225 obo. snatch this up quick before it goes on ebay.
Here is my ebay feedback: http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback&userid=b_hart29&item=-1&frompage=222
Frequency Response 5 Hz to 50 kHz +/– 3 dB
Number of Channels 3
Watts per Channel @ 4 OHMS 2 x 50 + 1 x 100
Watts per Channel @ 2 OHMS 2 x 100 + 1 x 200
Stereo Ch. Bridged @ 4 OHMS 1 x 200
Distortion (THD)
Signal to Noise Ratio > 100 dB
Damping Factor > 200 @ 100 Hz with 4½ Load
Input Sensitivity 100 mV to 8.5 V RMS Unbalanced Source
100 mV to 17 V RMS Balanced Source
Input to Line Output Gain 0 dB +/– 20 dB, Selectable in 10 dB Steps
Line Outputs: Yes
Crossover CM12HP & CM12LP Included
Module Ports 4 for Amplifier and 1 for Line Outputs
Power Supply Fully Regulated, Pulse Width Modulated
Operational Voltage 11 to 15 Volts
Fusing No On-Board Fuse
Fusing Requirement 60 Amp
Size (L x W x H) 18.5 x 7.6 x 2.25”
MSRP $400
i guess ill post here since u dont seem to wanna answer my pm...
is it brand new bought from an authorized dealer? is it refurbished, b-stock, or been repaired? does it include the original box or bill?
can you check for the crossovers? they should not be installed in the amp, they should just be in the box... if it is new, as you say...
groov2
groov2
Vancouver, BC
Exaran
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
