Xmech
you plan on throwing your XXX to Xmech?
oh no, im just curious. re doesnt provide the Xmech on their specs, which of course, is not really necessary as it is not an spl sub. come to think of it i dont think they provide the Xmech on any of their subs...
most companies omit xmech, because to the less knowledged, it can be a misleading spec..
any woofer that makes a trip to xmech.. only makes it one time... because xmech is a hard limit..
spider to landing
coil to backplate
cone to basket
xmech is a very bad place for a woofer to be..
Loyd L.
...so the Xmax is the Xmech for the xxx? im still a bit confused. so the xxx max excursion is about 3 in p-p? ive got to do some researching on the fields of a driver being "over hung" among others as well...
I remember on RE's forums someone saying something along those lines. The driver is very limited on X-mech due to the design. Like everyone already said, who cares?
I don't know if the basket would even allow 3" p2p. I believe you are pretty well hard limited to about 34mm rearward with that basket...
Thats why you use a semicup spider that allows for an extra 8mm rearward. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
vasilios
vasilios
Chandler, Arizona
jlaine
