xmax of an L7
Well, the Xmax isn't shabby. If you are snapping tinsel leads, then you are likely exceeding the Xmax. Stiff or not, given the right circumstances it isn't difficult to push a sub beyond what it was designed to do.
im not even pushing a full 750 watts to it, and my gain is weigh down, maybe im just not used to a sub with pretty good xmax
Xmax is what 15-16mm on the 12L7?
if you are breaking tinsel leads then you are significantly exceeding not only the maximum linear travel, but also the maximum safe mechanical travel as well.
Keep the excursion down a bit, unless you want another damaged L7.
Not being used to it is no excuse for breaking a tinsel lead during normal usage. That is very rare, especially when it is being underpowered.
17mm I believe.
Well what size/type of box do you have it in?
mine move quite a bit, but I havent had a problem w/tinsel leads breaking
but I have had the spider seperate in the middle. also make sure you have a ssf with ported boxes
I have a pair of L7's in a subzone ported box. 600W each from PPI PC 2600's with a SSF. No problems with mine in the year and a half I have had them
Knocks on wood...
The Xmax of an S12L7 is 13 mm ...
http://www.kicker.com/images/manuals/04Solo%20Baric%20L7%20Subwoofer%20Manual.pdf
Which isn't a whole heck of a lot //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
yea i was thinking it wasnt suppose to be alot of xmax, i mean its not comparable to vids of like XXX's and Brahmas ive seen that are coming like out past the surround it just looks like its going good. i'll try and get a vid of the xmax tonight/tommorow and post it up and see what u guys think.
jtomsic
jtomsic
Washington, Pennsylvania, United States
bamaboy
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
