WTTF: High power 4 channel or ?
WashYourWinky
The Pilot
Looking to trade for a high power 4 channel or maybe 2 channel? Trade for a head unit?
I have a few amps to trade with.
Eclipse EA3532 5 channel amp. Cosmetic 8/10 Mechanical 10/10
Specs:
* ChannelFlex Crossover
* Adjustable High-Pass Frequency (50–200Hz for Front)
* High-Pass Frequency (120Hz for Rear)
* Adjustable Low-Pass Frequency (50–200Hz for Subwoofer)
* High-Current, High-Speed Output Devices
* High-Efficiency, High-Energy MOSFET Power Supply
* Audiophile Grade Component Selection
* Intelligent 7-Way Discrete Protection Circuitry
Amplifier Type: Multi Channels
Bridgable: Bridgable
RMS Power at 4 Ohms: 40 W x 4 + 120 W x 1
RMS Power at 2 Ohms: 60 W x 4 + 120 W x 1
Performance
Frequency Response: 20 Hz - 20000 Hz
Signal to Noise Ratio: 105 dB
Crossover / Equalizer
Bass Boost: Without Bass Boost
Low - Pass Frequency: 50 Hz - 200 Hz
High - Pass Frequency: 50 Hz - 200 Hz
Other Features
Input Voltage: 13.8 volt
MOSFET Circuitry: Yes
Dimensions
Width: 15.75 in.
Depth: 10.82 in.
Height: 2.04 in.
Rockford punch 200A IV Cosmetic 7/10 Mechanical 10/10
Specs: http://www.rockfordfosgate.com/scrip...ted=1083353454
Autotek SX2200 Cosmetic 7/10 Mechanical 10/10
125 Watts X 2 Channels @ 4 Ohms
200 Watts X 2 Channels @ 2 Ohms
250 Watts X 2 Channels @ 1 Ohm
400 Watts X 1 Channel @ 4 Ohms Bridged
500 Watts X 1 @ 2 Ohms Bridged
Full MOSFET Circuitry
Fully Adjustable X/Over
Regulated Power Supply
True 2 Ohm MONO
0-18 dB Variable Bass Boost @ 43Hz
Adjustable Line Outputs
Therma-Cool Heat Sink Design
4-AWG Molded Terminals
Chrome-Finish Heatsink
Chromed Front & End Panels, Maxi Fuse
CFA-202 Pretty good condition, some scratches.
Specs:
50x2 @ 4ohms
100x2 @ 2ohms
200x1 @ 4ohms bridged
-all rated @ 12v
CFA-142 Like new in box.
Specs:
35w x 2 @ 4 ohms
70w x 2 @ 2 ohms
140w x 1 @ 4 ohms
Rated at 12 volts!
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
WashYourWinky
