WTTF: High power 4 channel or ?
WashYourWinky
The Pilot
Looking to trade for a high power 4 channel or maybe 2 channel? Trade for a head unit?
I have a few amps to trade with.
Eclipse EA3532 5 channel amp. Cosmetic 8/10 Mechanical 10/10
Specs:
* ChannelFlex Crossover
* Adjustable High-Pass Frequency (50–200Hz for Front)
* High-Pass Frequency (120Hz for Rear)
* Adjustable Low-Pass Frequency (50–200Hz for Subwoofer)
* High-Current, High-Speed Output Devices
* High-Efficiency, High-Energy MOSFET Power Supply
* Audiophile Grade Component Selection
* Intelligent 7-Way Discrete Protection Circuitry
Amplifier Type: Multi Channels
Bridgable: Bridgable
RMS Power at 4 Ohms: 40 W x 4 + 120 W x 1
RMS Power at 2 Ohms: 60 W x 4 + 120 W x 1
Performance
Frequency Response: 20 Hz - 20000 Hz
Signal to Noise Ratio: 105 dB
Crossover / Equalizer
Bass Boost: Without Bass Boost
Low - Pass Frequency: 50 Hz - 200 Hz
High - Pass Frequency: 50 Hz - 200 Hz
Other Features
Input Voltage: 13.8 volt
MOSFET Circuitry: Yes
Dimensions
Width: 15.75 in.
Depth: 10.82 in.
Height: 2.04 in.
Rockford punch 200A IV Cosmetic 7/10 Mechanical 10/10
Specs: http://www.rockfordfosgate.com/scrip...ted=1083353454
Autotek SX2200 Cosmetic 7/10 Mechanical 10/10
125 Watts X 2 Channels @ 4 Ohms
200 Watts X 2 Channels @ 2 Ohms
250 Watts X 2 Channels @ 1 Ohm
400 Watts X 1 Channel @ 4 Ohms Bridged
500 Watts X 1 @ 2 Ohms Bridged
Full MOSFET Circuitry
Fully Adjustable X/Over
Regulated Power Supply
True 2 Ohm MONO
0-18 dB Variable Bass Boost @ 43Hz
Adjustable Line Outputs
Therma-Cool Heat Sink Design
4-AWG Molded Terminals
Chrome-Finish Heatsink
Chromed Front & End Panels, Maxi Fuse
CFA-202 Pretty good condition, some scratches.
Specs:
50x2 @ 4ohms
100x2 @ 2ohms
200x1 @ 4ohms bridged
-all rated @ 12v
CFA-142 Like new in box.
Specs:
35w x 2 @ 4 ohms
70w x 2 @ 2 ohms
140w x 1 @ 4 ohms
Rated at 12 volts!
What does the sticker on the Eclipse say ? I can see where it says Do not remove this tag...but I can't read the rest for reason
Until after all connections are secured
Be sure to disconnect all power supply sources prior to connecting this product. Failure to do so may result in damage to the unit or an electrical fire.
I'm interested in the 4.100 or the 1.600. What kind of trade are you thinking?
sorry, just looking for cash. these are up for sale because i just bought a new trio of jbl ms amps. no need for any gear other than a set of dyn md100 or md102.
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
WashYourWinky
