WTTF: Head unit or D2 12" sub
WashYourWinky
The Pilot
I have 2 sets of 6.5" coax speakers and one 4 channel amp to trade with.
Looking for a head unit or a D2 10 or 12" sub. Might trade for an Android T-Mobile phone.
Alpine SPS-17C2 6.5"
Mechanical 10-10 and Cosmetic 8-10
specs:
2-way car speakers for 6-1/2" and 6-3/4" locations (pair)
aluminum-coated woofer cone with air-injected rubber surround
1" pivoting silk dome tweeter
square voice coil design and Nomex spider
power range: 2-50 watts RMS (250 watts peak power)
frequency response: 35-30,000 Hz
sensitivity: 92 dB
mounting tabs for use in 6-3/4" openings
top-mount depth: 2-1/4"
Rockford Power T162C 6.5"
Specs:
6-1/2" Power Series 2-way Car Speakers
Power Handling:
Peak: 300 watts per pair / 150 watts each
RMS: 150 watts per pair / 75 watts each
Injection molded polypropylene cone woofer
Polyurethane surround
3/4" Aluminum dome tweeter
12dB Crossover
4 ohms impedance
Kapton voice coil former
Proprietary cold rolled steel vented basket
MTX RT 4240 4 channel amp
Cosmetic 8/10 Mechanical 10/10
Specs:
RT4240 Amplifier
RMS Power measured at 12.5 Volts DC:
45 Watts x 4 into a 4 Ohm load with less than .5% THD
60 Watts x 4 into a 2 Ohm load with less than 1% THD
120 Watts x 2 bridged into a 4 Ohm load with less than 1% THD
Dynamic Power (IHF-202 Standard) measured at 14.4 Volts DC:
55 Watts x 4 into a 4 Ohm load
100 Watts x 4 into a 2 Ohm load
200 Watts x 2 bridged into a 4 Ohm load
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
WashYourWinky
