WTT: Sundown 3k for Flip out in dash HU with nav.
rollerdj
Low End Master
1. Product:
Brand new Sundown SAZ-3k
2. Specs:
Double Sided Through Hole Epoxy PCB
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Digital Class-D Linkable Mono Block Amplifier
1 Ohm Stability
RCA Line Input and Master Output
24dB Octave Crossover Slope
Wired Remote Controller
Rated power output ----RMS power, 2 ohm linkable/dual mono
6000W x 1CH----RMS power, 1 ohm mono
3000W x 1CH----RMS power, 2 ohm mono1600W x 1CH----RMS power, 4 ohm mono
800W x 1CHSignal to Noise Ratio>90dBLow pass frequency crossover35Hz~300HzSubsonic filter10Hz~60HzBass boost @ 45Hz0~18dBPhase shift control0~180 degreeFrequency response10Hz~350Hz (+/- 1dB)T.H.D @ 4 ohm
3. Description/Condition:
brand new, used for 5 min to test out amp and sub. vinyl done by a business that does a ton of work for me.
4. What you are looking for: :
Pioneer AVIC-N5
Pioneer AVIC-N4
Kenwood P-NAV514
what ever the Kenwood 25th anniversery version of flip out HU was.
anything simular.
Has to be a single Din. I will not trade for other amps or speakers.
5. Pictures of your item for trade:
I have a pioneer avic N1.it has navi,7'' touch screen,dvd\tv,cd,ect.it is in great shape and works great.I don't have the rca plug or the wire harness plug,but got the hu,brain,data cable,gps ant.,regular ant.I will give you the cash that it will cost you to order the plugs.lmk,thanks
rollerdj
Low End Master
rollerdj
Bloomington IN
Evilkefz
