1. Product:
Brand new Sundown SAZ-3k
2. Specs:
Double Sided Through Hole Epoxy PCB
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Digital Class-D Linkable Mono Block Amplifier
1 Ohm Stability
RCA Line Input and Master Output
24dB Octave Crossover Slope
Wired Remote Controller
Rated power output ----RMS power, 2 ohm linkable/dual mono
6000W x 1CH----RMS power, 1 ohm mono
3000W x 1CH----RMS power, 2 ohm mono1600W x 1CH----RMS power, 4 ohm mono
800W x 1CHSignal to Noise Ratio>90dBLow pass frequency crossover35Hz~300HzSubsonic filter10Hz~60HzBass boost @ 45Hz0~18dBPhase shift control0~180 degreeFrequency response10Hz~350Hz (+/- 1dB)T.H.D @ 4 ohm
3. Description/Condition:
brand new, used for 5 min to test out amp and sub. vinyl done by a business that does a ton of work for me.
4. What you are looking for: :
Pioneer AVIC-N5
Pioneer AVIC-N4
Kenwood P-NAV514
what ever the Kenwood 25th anniversery version of flip out HU was.
anything simular.
Has to be a single Din. I will not trade for other amps or speakers.
5. Pictures of your item for trade:
2. Specs:
Variable Bass Boost
1 Ohm Stability
Pioneer AVIC-N5
Pioneer AVIC-N4
Kenwood P-NAV514
anything simular.
