This is just a feeler thread guy's. Im still thinking about it want to trade my DLS A3 twin mono amp for something with more rating. looking for like 2500@1ohm or something like that cause i found out this amp would only be giving like each my subs 600 a piece basically and they are rated at 1000rms a piece. here is the specs of the DLS A3 amp.
Number of channels 2
Amplifier class AB
Output power in 4 ohm 2 x 150 W
Output power in 2 ohm 2 x 270 W
Output power in 1 ohm 2 x 425 W
Mono bridge mode 4 ohm 550 W
Mono bridge mode 2 ohm 870 W
Mono bridge mode 1.33 ohm 1000 W
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Input impedance, high level N/A
Input sensitivity 0,2 - 7 Volt
Input impedance > 10kohm
Frequency range 10 Hz - 50 kHz
High pass filter 20 - 200 Hz
Low pass filter 50 - 125 Hz
External cooling fan terminal 1
Dual DC inputs 1
Power consumption (idle) 1,1 A
Power consumption (max) 140 A
Rec. power cable Minimum 2AWG / 33 mm2
Fuses 4 x 30 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight 6,2 kg ( 13,67 lb)
Also can get pics of amp np at all.
Amplifier class AB
Dual DC inputs 1
Fuses 4 x 30 A
