WTT for 400-500rms amp, 4awg Wire Kit, etc.
Eclipse 8445 8volt head unit - It has 4 sets of preamp out puts! REAR , FRONT and NON-FADER. It also has AUX output, CD CHANGER plugin as well as a SIRIUS plugin. Eclipse doesn't make this 8volt head unit any longer!! Comes with harness, manual, remote, mounting hardware, 2 trim rings and an extra faceplate and faceplate ribbon. . Last time I looked these sell for $399.99 new and around $250 on ebay IF you can find them. Considering there disconnected you could be hard pressed to find any on ebay. [/i]
WELL I DECIDED TO JUST FIX THE ECLIPSE CD8445 HEAD UNIT. ILL HAVE IT FIXED BY THE 2ND OR SO AND ILL POST UP NEW PICS WITH IT ALL WORKING 100%. ASKING PRICE IS GOING TO GO UP DRASTICALLY THO... 8 VOLT PEROUT PUTS!!!
Specs:
ESN E8 High-Power "Customize" CD/MS Receiver with MP3/WMA playback and Remote
CD/CD-R/RW, MP3, WMA playback
MOSFET 50 watts x 4 channel power output
High 8 volt preamp outputs MAD GOOD! 8v preouts let you get louder (quicker) at lower volumes. Very rare! most units are only 2.5 to 5v.
Wireless remote included
3 pairs of preamp outputs (front, rear, and sub)
Circle Surround II Sound
E-iSERV connectivity This means when reading CDs it reads 60 seconds in advance which eliminates skipping.
Area Shot (basic map, arrow and text)
5-pattern various color illumination
Motion picture display
SIRIUS Satellite Radio Ready (tuner, antenna and subscription required and not included)
Advanced 2-mode Sound Control DSP:
7-band Parametric EQ (advanced mode on)
Speaker Time Alignment (to make the sound always sound centered to your position)
Crossover
Listening Position Selector
Multi-Harmonizer
Source Volume Control
Memory-stick ready for other MP3/WMA playback option
Advanced 24-bit Digital-to-Analog Converter
HD radio-ready (tuner required)
GPS unit-ready (GPS add-on required)
FM/AM Tuner
8-step full dot VF display
MS/CD ESN security
CD Text support
Aux input
THIS UNIT IS AN EXPENSIVE ONE. RETAILS FOR $400 AND HAS RARE 8 VOLT PREOUT PUTS!!. EVERY THING WORKS NOW 100%!!.
I popped the unit open and found that one of the capacitors broke off some how.
Which I fixed!!
I found the manual and another faceplate trim ring. You also get the extra face plate and faceplate ribbon that I bought. (To fix the original problem but ended up not needing but I switched out anyways.)
Video Of the headunit working 100%
TTT AudioControl Epic-150 still up fro grabs....... You can add a DC lvl 2 or a SA-8 (d2 coils preferably, but d4 is fie aswell) to the items of intrest.
sojiaraggs9000
sojiaraggs9000
West Tx
sojiaraggs9000
