WTT for 400-500rms amp, 4awg Wire Kit, etc.
sojiaraggs9000
Just trying to see if I can get anything decent. My little sister need some bass lol. Can add cash if needed. Copy n pasted from my SMD post .. if new pics are needed I take them just let me know
Items Of interest:
. 400+ watt amp. (400+ RMS @ 4 ohm or 1 ohm.)
. 8 Gauge to 4 Gauge Complete Amp Kit
. A decent Line Out Converter
**NEW GEAR ADDED FOR TRADE!!**
Audio Control Epic-150 - I made up a cigarette lighter hook up for it. Works great I only used this for testing voltage and how a newly built box rated on the 150db SPL meter it has. (How close is the meter to a Termlab? I don't know, never had it tested) -
Specs:
Bass Restoration processor with SPL Display
SPL Display with Microphone Included
Para-BASS EQ
Patented Pass Restoration Circuit
Battery Voltage Indicator
Speaker Level Inputs
Balanced Differential Inputs
White LED Underglow Kit - BNIB (Brand New In Box) Full underglow kit never been used. It also has a wireless remote feature. Just opened the box today to take pictures -
Griffin iTrip - "The Griffin iTrip is a tiny and compact FM transmitter built for iPods. Once connected, users can tune into FM radio stations anywhere from 88.1 up to 107.9. Plus, the unit sports selectable LX or DX modes of broadcasting, which means superior sound quality with reduced background interference." - Had this for a couple years only used it for a bit before I got my iPod adaptor for my Eclipse Headunit. This Griffin iTrip works great. - iPod not Included, was just used to show the Griffin iTrip works.
WELL I DECIDED TO JUST FIX THE ECLIPSE CD8445 HEAD UNIT. ILL HAVE IT FIXED BY THE 2ND OR SO AND ILL POST UP NEW PICS WITH IT ALL WORKING 100%. ASKING PRICE IS GOING TO GO UP DRASTICLY THO... 8 VOLT PEROUT PUTS!!!
Eclipse 8445 8volt head unit - The head unit powers on , knobs work and light up and everything. But the display isn't working so you can't see what your doing. If you can find a faceplate it will be good as new. IIRC eBay has one for like $27. You might also be able to fix by just replacing the ribbon. Ill try looking into that. It has 3 preamp out puts! REAR , FRONT and NON-FADER. It also has AUX output, CD CHANGER plugin as well as a SIRIUS plugin. Eclipse doesn't make this 8volt head unit any longer!! Comes with harness. Last time I looked these sell for $399.99 new and around $200 on ebay IF you can find them. Considering there disconnected you could be hard pressed to find any on ebay.
Specs:
ESN E8 High-Power "Customize" CD/MS Receiver with MP3/WMA playback and Remote
CD/CD-R/RW, MP3, WMA playback
MOSFET 50 watts x 4 channel power output
High 8 volt preamp outputsMAD GOOD! 8v preouts let you get louder (quicker) at lower volumes. Very rare! most units are only 2.5 to 5v.
Wireless remote included
3 pairs of preamp outputs (front, rear, and sub)
Circle Surround II Sound
E-iSERV connectivity This means when reading CDs it reads 60 seconds in advance which eliminates skipping.
Area Shot (basic map, arrow and text)
5-pattern various color illumination
Motion picture display
SIRIUS Satellite Radio Ready (tuner, antenna and subscription required and not included)
Advanced 2-mode Sound Control DSP:
7-band Parametric EQ (advanced mode on)
Speaker Time Alignment (to make the sound always sound centered to your position)
Crossover
Listening Position Selector
Multi-Harmonizer
Source Volume Control
Memory-stick ready for other MP3/WMA playback option
Advanced 24-bit Digital-to-Analog Converter
HD radio-ready (tuner required)
GPS unit-ready (GPS add-on required)
FM/AM Tuner
8-step full dot VF display
MS/CD ESN security
CD Text support
Aux input
THIS UNIT IS AN EXPENSIVE ONE. RETAILS FOR $400 AND HAS RARE *VOLT PREOUT PUTS!!. EVERY THING WORKS BUT THE CENTER DISPLAY. WHICH CAN BE FIXED BY EITHER REPLACING THE FACEPLATE OR POSSIBLE JUST THE RIBION CONNECTING THE 2.
I got a video uploaded, its processing tho give it a sec. The video shows what i mean about the head unit. It functions 100% except for the display area doesn't work.
Yeah its pretty decent its a Kodak v1073. Its a 10 mega pixles, touch screen, takes HD videos with pretty decent sq. Although i should re-size them pics lol I bet it kills some peoples PCs. Althogh I like using the big pics because people can't say "well i didn't see blah blah blah"
sojiaraggs9000
sojiaraggs9000
West Tx
sojiaraggs9000
