WTT DD2512D2 for your 4 channel
KWConch021
Louder Than You
I am willing to trade this beauty of a sub for a 4 channel amp pushing at least 150 rms per channel. I will also take two 2 channels, one will have to be at least 150 rms per channel with te other being at least 250 per channel..
Depending on values involved, I may ask you for cash, please don't be offended.
I also have this posted in the sub category but I figured I'd spread it around..
750rms minimum on this sub, 3000 max. I had it at just under 1400 and it is amazing.
A I believe. My plans would be to replace my components for dd's highs in the doors and in the rear deck put their 6.5" subs. Still retaining all my trunk space.
So my Fosgate P6002 wont work? There pretty underrated, and it looks literally bran new. Ill add $
300 x 2 @ 2ohm
150 x 2 @ 4ohm but ive heard there up to 100wrms per channel underrated, prob more like 60-75 but its a beast for sure
well like i said im willing to trade my amp, specs are pretty much identical to the mtx te1004. i have a blown 2510a i can get reconed to a 12.
so are these underrated??
MTX TA7804 4-Channel Super Amplifier Thunder7804
specs show 100rms at 4ohm per channel
it may be too little power for my application. the new 6.5's i would be getting need a minimum of 250 each, and the components would be at 150 each. My rear doors do not have speakers, so i would only need a total of 4 channels. 2 of those channels would be higher power.
josh clear your pm's.
so are these underrated??MTX TA7804 4-Channel Super Amplifier Thunder7804
at bare minimum it will giveu 120x2@4ohm on the fronts and if u bridge the rear u will get around 500x1@4
hell it was mtx's biggest four channel at the time and there most expensive it is most definitely underrated and will push whatever u have fine. those dd 6.5sw only need 200watts anyway and unless u are putting their german made components u dont need 150w. u wont hear the difference in 50w anyway. ive ran dd for years and ive never needed anything over rms to achieve high volumes.
Oh me either. The components I would get would also be dd's and they require 160. I would put at least 150 to each and I would have two of those 6.5 subs. So with bridging the rear, I would have to have a distro block or something.
The spec sheet on the website says 160.
then call them directly and they will saythatthey can take 160 but it isnt required what amp do they make for it ehh the s4b which is 100x2front and 200x2rear or if your just really not interested just say so for what you want the dd s4b is the only amp i know with staggered outputs
KWConch021
Louder Than You
KWConch021
Key West, FL
KWConch021
