WTT: Amps and Comps
whitedragon551
Moderator
Item:
Eclipse EA3532
Eclipse XA5000
Eclipse SC6500's
Specifications:
EA3532
* ChannelFlex Crossover
* Adjustable High-Pass Frequency (50–200Hz for Front)
* High-Pass Frequency (120Hz for Rear)
* Adjustable Low-Pass Frequency (50–200Hz for Subwoofer)
* High-Current, High-Speed Output Devices
* High-Efficiency, High-Energy MOSFET Power Supply
* Audiophile Grade Component Selection
* Intelligent 7-Way Discrete Protection Circuitry
Amplifier Type: Multi Channels
Bridgable: Bridgable
RMS Power at 4 Ohms: 40 W x 4 + 120 W x 1
RMS Power at 2 Ohms: 60 W x 4 + 120 W x 1
Performance
Frequency Response: 20 Hz - 20000 Hz
Signal to Noise Ratio: 105 dB
Crossover / Equalizer
Bass Boost: Without Bass Boost
Low - Pass Frequency: 50 Hz - 200 Hz
High - Pass Frequency: 50 Hz - 200 Hz
Other Features
Input Voltage: 13.8 volt
MOSFET Circuitry: Yes
Dimensions
Width: 15.75 in.
Depth: 10.82 in.
Height: 2.04 in.
XA5000Full range class D with Bang and Olufsen ICETechnology
Eclipse XA5000 - 5-Channel Car Amplifier/Amp - Sonic Electronix
Description/Condition:
Both amps are used in near mint condition, 100% functional, a 9.5/10 physical.
Comps are new out of box, never seen power, only a DMM. Missing the grills and tweeter hardware.
What Are You Looking For
A pair of matching amps, one for sub duty the other for active front stage duty. Not looking to downgrade to Kicker or anything like that. I want SQ.
If I cant find a pair of matching amps I want to trade the XA5000 and the comps, depending on amp. Looking for a sub amp 500@2 or 500@6 ohms. Id love to try a Zed Minilith or Zapco Ref 500.1, but all offers will be considered.
WTT thread, but so you have an idea of what they are worth Ill go with eBay pricing for similar condition equipment.
EA3532 $140
XA5000 $240
SC6500 $100
Pictures (MANDATORY PICTURES WITH USER NAME & DATE):
FEEDBACK LINK IN PROFILE.
EA3532 $140
XA5000 $240
SC6500 $100
What are you looking for?
Whoops. Must have missed it when I copied everything over. I updated the OP to reflect this.
whitedragon551
Moderator
whitedragon551
IL
Slayerx
