Jason19
I have a nice hifonics colossus amp that im looking to trade for a smaller amp im looking for around the same power or can be less but with a smaller heatsink this amp is just way to **** big its about 35 inches long anyways the amp is not perfect has a few scratches nothing bad aslo does not have the mounting feet but some could be made very easy here are the specs on the amp.
600W x 2 @ 4 Ohms
1100W x 2 @ 2 Ohms
1600W x 2 @ 1 Ohm
2000W x 1 @ 4 Ohms
3200W x 1 @ 2 Ohms
Slow Un-Mute Turn-On
Frequency Response: 2Hz - 250Hz
Dampening Factor: 400
S/N Ratio : 98dB
THD & N: 0.10%
Variable Input Level Control: 0.2V-9V
Input Level Control: 0.04V-18V
Variable Input Impedance: 0.6k - 47Kohm
Input Impedance: 20Kohm
Power/Diagnostic L.E.D.
DC, speaker short, thermal, overload
Power Supply MOSFET
Audio Output MOSFET
Variable Low Pass Filter/24dB - 35Hz-250Hz
Variable Subsonic Filter - 10Hz-50Hz
Variable Bass EQ - 0-18dB between 30Hz - 60Hz
Phase Shift (0-180 degrees)
Unbalanced Inputs (RCA)
Balanced Inputs (DIN)
Line Output ( RCA) - High Pass
Speaker Terminals - 10 ga.
Power/Ground Terminals - 2 ga. x 2
Remote Bass Module WBR-1 (Rj11)
Dimensions (LxHxW): 11.28 " x 2.68" x 40.52 "
600W x 2 @ 4 Ohms
1100W x 2 @ 2 Ohms
1600W x 2 @ 1 Ohm
2000W x 1 @ 4 Ohms
3200W x 1 @ 2 Ohms
S/N Ratio : 98dB
THD & N: 0.10%
Power Supply MOSFET
Audio Output MOSFET
