WTT: 2 Cadence Amps
Ninja Primate
1. Product:
I have a Cadence Z1200. Near mint condition. Has a few hairline scratches on the orange plates.
The other is a Cadence TXA3004 that is BNIB. I removed to take pics and thats it.
2. Specs:
Z1200
1 Ohm Mono Power 1200 watts
Frequency Response 10Hz - 40KHz
Signal/Noise Ratio >100dB
Damping Factor > 200 @ 100 Hz
Minimum THD
Channel Separation >65dB
Input Voltage 150mV - 8 Volt
Dimensions 19” x 10.75” x 2.4” (LxWxH)
TXA3004
4 Ohm RMS Power: 4 x 75 Watts @ 13.8 Volts
2 Ohm RMS Power: 4 x 150 Watts @ 13.8 Volts
4 Ohm Bridged RMS Power: 2 x 300 Watts @ 13.8 Volts
Frequency Response: 20Hz - 30kHz
Damping Factor: >200 @ 100Hz
S/N Ratio: >100 db
Channel Seperation: >65dB
Minimum THD:
Dimensions: 17" x 9.2" x 2.12"
3. Description/Condition:
Z1200 was used at 1-ohm with proper voltage and settings with a DMM.
TXA3004 was never used. Has only seen human hands 1 time.
4. What you are looking for: :
Looking for an AQ1200 and a matching 4 channel amp or an eD Nine.1 and matching 4 channel amp. Would also take American Bass, US Amps, possibly some Memphis amps, MB Quart (before they were owned by Maxxsonics), Kicker, Alpine, etc. NO JL Shit. Will also take other matching monos and 4 channels as long as the mono does 1200@1 ohm and is as under rated as the Cadence. Will trade each to seperate people as long as I have trades for both setup. Only reason for trade is Im trying to do a matching setup. Both amps are Cadence, but I couldnt find a matching Z4300 amp to go with the Z1200.
5. Pictures of your item for trade:
Z1200
TXA3004
ttt
Apparently Cadence wont send me the piece and dB-R and ampjunkie dont have the available connections to get the piece. Ampjunkie may be modding it, if he doesnt I am. Ill be installing fans before its every hooked up. It may over heat or it may not. However I will not know since it has never been installed. Better to be safe than sorry.
Ninja Primate
Ninja Primate
Behind You?
Ninja Primate
