WTS/WTT TC 4hp motor, bnib 4in D2 coil, TRF 15 basket
BassAddictJ
FL
This pains me to do....but my 4hp rebuild project has been put on the back burner since I bought a new TV on black friday.
TC 4hp motor from a Team RF 15. Non threaded, but male QCA adapters are obtainable should you need one. Does come with the screws to mount a basket. This is a SILVER TOP PLATE, it has the wider gap than those black tops.
BNIB 4in D2 Coil. It's alluminum, and I THINK it's 4 layer but I'm not positive.... check the pics and someone chime in if they know for sure.
TRF 15 basket.
4hp motor:
some wear, but overall good condition. no cranks or misalignment. very minor chipage here or there. nothing more than a small bit of magnetic dust on the magents... common with these motors. no real damage, works like a champ. the top and bottom plates used to be shiny and ****, but my daughter got a little bit of water on the bottom plate and while in storage it discolored a bit. good news is with minimal amount of TLC via high grit sand paper you can make the plates dead **** again.
Coil:
BNIB
Basket:
Needs to be cleaned. Has some scratches and dried up glue but no cracks or defects. The wire mesh is in mostly in good shape, only one mess section has a hole in it. I also have a rubber gasket not pictured, but will be included.
I'd prefer to trade all this for a working SPL sub......BTL, DP, 9500, MT......has to be a 15, and has to be give me a 1 ohm mono load (D2, Q4, D.5)...A woofer that works well in a small ported box (3 cubs @ 33hz) and can take 3kw+ daily.
Cash price is 300+ ship OBO for the motor, coil, and basket. Closer to FL you are the better deal I can make w/ the shipping.
I really only want to part these out if I land a home for all 3 pieces.
USPS Insured
this is what the motor used to look like, and can easily be restored to.
Coil:
  • Locked
Must have been the 3" version that had the unobtainium coils that I'm thinking of. As you say 4HP coils should be easy to find and I think...
BassAddictJ
BassAddictJ
FL
BassAddictJ
