wtf is this clamp result
Based
Yesterday I clamped my Taramps HD3K 1 Ohm wired to 1 ohm nominal with a 40hz tone and I got 63.4 ac volts and 15.46 ac amps. Shouldn't I be getting a little more amperage?
Electrical is 320a singer alternator, agm 65 in the front 75AH and Kinetic HC2000 in the back 100 AH.
Did you measure voltage at the amp? Are you setting your max output by a scope or using the on board clip indicator? Does sound like it has more in it.... Meter wise what are you using?
yeah I measured the dc volts at the amp's ground and positive inputs. steady 14.4. I'm using the amp's clip light. It has been tested and shown to be accurate.
I'm using a Klein CL2000 for the clamp and a Klein something 200 for my DMM. Both are True RMS.
Based
Based
Louisiana
garychoffmann
