Rashaddd
Terrrrrist
okay so same sub as in this thread: http://www.caraudio.com/forum/showthread.php?t=364649
i went ahead with the amazing goop worked very well...looks decent, hooked it up now after letting it cure for a while
in the upper sub bass range, like 40-80hz region, the sub makes a sound almost like bottoming out except not as bad, sounds like the voice coil is rubbing or something...but below that in like the 10-40hz range, with it excurting even more, it sounds fine...what could be making it do this and is there anything i can do about it short of a recone...?
I really don't think it has anything to do with the fix i just did on the surround, that seems to have worked out perfectly from a mechanical standpoint...
idk...any suggestions?
