Wtf charging help anyone?
i haven't tried jsut one battery at a time b/c that would mean i would have to tkae off my buss bar, which i might actualy do tonight and i will give an update on what happens!
Kenneth
hey guys i got a reply back from them and heere is what they said to do to fix this!
Try doing this test:
Connect output clamps to battery posts.
Press and hold CHARGE RATE button.
While still holding the button, plug in AC power cord.
Once AC power cord is plugged into outlet release the CHARGE RATE button.
This will set the processor into a Manual 2 amp mode. Leave this mode go for
About 1 hour, after that time unplug AC power cord and then re-plug AC power
Cord for the processor to reset. Now any selection you choose should see the
Battery and begin charging the battery the rest of the way.
Sincerely
Schumacher Electric Corp
Technical Support
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
14.6 is max charge for headway. 3.65 volts per cell. There should not be any voltage drop from your alternator wiring to battery so 14.8 is too high.
How often are you charging? I charged mine once when I built it over a year ago and maybe a couple times while I had the car pulled apart. I...
For the pt cruiser, neons, and other pcm controlled charging systems these parameters need to be altered with tuning software. The two tuners I...
CrazyKenKid
CrazyKenKid
Canada
CrazyKenKid
    May 20, 2024
    May 20, 2024
