Wtb/wtt For Stetsom 2k6d
simply to run em at the 18v... sundown is a nice amp, clean power looks awesome ect but at the end of the day i need something to run at 18v a single 2k6d is the wrong impedance actually... 2 would be the ultimate and final goal
not that I am offically telling you to do so, but If you look over on SSA (i think, it may be on here also) you will find a link where the 3000d has been run at 18volts and put out some serious numbers.
The SAZ3000D is made to run at 18 volts. Hell, I use to run mine at 12volts at 0.5ohms. That sucker would give out over 3k on music. So take it from Dtbrown and I, you will not see a difference in gain, and we run Stetsom!!
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=7900
click that link. they do put out serious #'s at higher voltages as jacob shows.
that was at 16.5 dropping to 14.5. my batteries rest at 17v with a recommended charging of 18.8-19.2 but my alt is set just above 18
as ive herd but mine doesnt. it gets pissed at the high voltages. Trust me im not looking to gain power but more so the ability to run my batteries as intended at 18v. I just hooked the sundown back up to 12v and its plenty for me but i have a 16v electrical so
the alt is an externally regulated ohio gen. power wire to the back is rockford fosgate 2/0 to 2 kinetik HC16v's connected in parallel with same 2/0 and to the amp
im also planning on running a ground from the alt ground up front to the batteries in the back
emperorjj1
Type RF
emperorjj1
Las Cruces, NM
emperorjj1
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
