Sold WTB NOW!!! sub and amp
lovindabass
Banned
I am looking to spend around 700 total for a sub and amp. I want something decent and quality. Let me know what you have? Thanks! I was selling my audiobahn immortals and rack mount amps and someone jacked my stuff so I need to replace them! ASAP I need 1 12 or 15 and an amp to boot.
I'm quoting Ampguts. When it has the same board as the American Bass XD3000 that is only capable of 1 x 1471.4 watts @ 1 ohm.... thats all. Not to mention that every time i've seen this amp in a forum its being trashed and also being said that people would rather spend the money on a sundown not this amp... thats all. I'm not only gathering information from a singular sorce. I do my research before I say anything.
pulling more info to throw in the ring
Icon 1 posted 06-25-2005 09:42 AM Profile for React Systems Author's Homepage Email React Systems Send New Private Message Edit/Delete Post Reply With Quote did this testing a few weeks ago, but thought i would share...
simple test with the TermLab [smile]
system was 1 XXX 15" sub in a big *** ported box, wired to show a single amp a 1 ohm load. 2 extra bosch silver tops in the boot, and engine running.
best score with the Solid = 140.0dB
best score with the PowerBass = 141.2dB (not 100% sure on the .2)
was approx 15-20 more volts (p-p) coming out of the PB too
however, the solids may come into their own at lower impedance, or higher voltage, other tests will need to be done in these cases.
but if you want a streetbass amp, go for the PB, it also has a fan inside and a better heatsink IMO [Wink]
Andy
[EDIT] just to add, the scores **** ***, this isnt the amps fault, the car we tested in is horrible for SPL, but the test was just to compare the 2 amps, ignore the actual score, just look at the difference! cheers!
Andy
http://www.talkaudio.co.uk/vbb/showthread.php?p=1366013
well after reading several of the posts on the forum you posted up for me They still all say the same thing in the end... but this convo is obviously going no where so.. You're intitled to your opinion and i'll have mine. Also pm's responded to!
lovindabass
Banned
lovindabass
brooks,Ga
lovindabass
