WTB: HU 3 5V preamp outs!
well cause kicking up the whole system (300 HO alt, 2 batts, 2 amps, and the jbls) i want something with a number im safe at. i have a Dual now and its something like .25V. and everyone is moving down to 4 now..
really and truly your preout voltage just dictates how high you have to set your gains. but generally speaking the higher the preamp voltage the better the HU is so i mean ur killing two birds with one stone. little easier on your amps if the gains are lower and since ur upgrading everything else u should upgrade the HU.
good luck.
i have an alpine 9811 that is in great shape if you are interested, its a 4 volt deck out the box but i think it can be manually set to 5, its been a minute since i messed with it but im sure it goes to 5 volts...it looks just like this one if you are interested i will snap some huge pics that way you can see what mine looks like...100 shipped fedex insured just let me know...thanks
nice pic, I took it //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif and it is a good HU, I wish I still had it.
im confused as to how a HU with 4 volt preouts can magically turn itself into 5 volt preouts. i dont get it.
if you go into the radio settings and turn off the internal amp...it bumps the preout voltage quite a bit...with flat settings out the box with the internal amp on it starts at 4 volts...turning it off and the numbers go up to 4.7vrms to a 5.5-6 v peak if you mess with the treb,bass and sub settings...turning off the internal amp and what not is all in the user manual and the voltage numbers are from alpine...
i hope that helps clear up some of the confusion.
jblw12gti
jblw12gti
papillion, NE
djman37
BP1Fanatic
BP1Fanatic
