The amp I'm going to get has 2x 4gauge inputs for power and ground(ghey).
I need a 2x 1/0 input and 2x 1/0 output MAXI fused distro. I need to be able to use either 1 fuse and still have current flow for both wires. I just need one of these by the way.
If you're wondering what it's for, I plan to add another 1/0 run and put both runs into the block. Then I will run 0 gauge with reducers to the amp. I need the MAXI fuse since this is for competition and I run 50amp fuses.
