WTB: Custom made fused distro
prochobo
Sedan Sleeper
The amp I'm going to get has 2x 4gauge inputs for power and ground(ghey).
I need a 2x 1/0 input and 2x 1/0 output MAXI fused distro. I need to be able to use either 1 fuse and still have current flow for both wires. I just need one of these by the way.
If you're wondering what it's for, I plan to add another 1/0 run and put both runs into the block. Then I will run 0 gauge with reducers to the amp. I need the MAXI fuse since this is for competition and I run 50amp fuses.
I'm switching to a Treo SSX1500.1. I remember you saying Littlefuses are weak, I guess I'm going to reconsider. BTW, I'm catching up to you in DB, just need to find a better song . . .
I could, but I'd have to use a 25amp on each wire.
Just remember that my scores all season have been with a single 10".
Which i'm not running at finals. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
And yes, littelfuses are weak. MUCH better options out there. The only problem is that you have to pay for the other ones. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Trunk vs Truck, this should be good.
prochobo
Sedan Sleeper
prochobo
louisville, ky
tommyk90
michigan born
    May 14, 2026
michigan born
    May 14, 2026
