WTB: Custom made fused distro
prochobo
Sedan Sleeper
The amp I'm going to get has 2x 4gauge inputs for power and ground(ghey).
I need a 2x 1/0 input and 2x 1/0 output MAXI fused distro. I need to be able to use either 1 fuse and still have current flow for both wires. I just need one of these by the way.
If you're wondering what it's for, I plan to add another 1/0 run and put both runs into the block. Then I will run 0 gauge with reducers to the amp. I need the MAXI fuse since this is for competition and I run 50amp fuses.
have you looked at the new stinger stuff? maybe hooker audio?there's a company XIO or something?? they've got a lot of that type of stuff.
Stinger doesn't have it. They only have 1/0 to 4 gauge MAXI. Hooker doesn't have em either. Can't find anything on the XIO company.
something like this ? yes i understand you want FUSED distro block.
i make all types of them.
or these by hooker .
the 1 in the middle .
has 2 1/0 in and 3 bolts on the other end for ring terminals.
but yes these are for ANL fuses.
not MAXI fuses.
something like this ? yes i understand you want FUSED distro block.i make all types of them.
or these by hooker .the 1 in the middle .
not MAXI fuses.
Yes! Something like the Hooker, but with MAXI fuses and 2x 1/0 out instead of bolts.
maybe you could make something... look here.
http://www.splbassx.com/forums/index.php?showtopic=8847
Im in need of the same thing. my amps can take 2 gauge each but Im gonna have 4 runs of 0 gauge. Hopefully after I build them this weekend I can show you. Ill have the all the power going to terminals with a maxi fuse holding together the 2 bars.
|maxi|
|maxi|
Its hard to explain but ill show you when its done.. Hopefully this weekend //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
What amp are you switching to that has dual 4 gauge in?
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
BTW, if you are using/plan on using littelfuse MAXI's, don't bother. I'll give you a little inside tip. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
FYI, i had littelfuse 25's, and they are friggin WEAK. In fact, i still have a bag of 49 of them if you want them. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
yea currently Im using a 20 and 30 amp maxi and they work better then 2 littlefuse 25's..
I'm switching to a Treo SSX1500.1. I remember you saying Littlefuses are weak, I guess I'm going to reconsider. BTW, I'm catching up to you in DB, just need to find a better song . . .
or you could just use the reducers on the stinger 0 to 4 gauge maxi holder
I could, but I'd have to use a 25amp on each wire.
prochobo
Sedan Sleeper
prochobo
louisville, ky
tommyk90
