WTB: Cheap amp
30 shipped for either 1 or 55 shipped for both.
around 250 watts at 4 ohms i do believe either 1
I have a DUAL amp..
rated at 580w at 4ohms bridged. I could do 50$ shipped, it's in great condition, and hardley used at all.
I also have a PA300d for 150$ shipped, which is rated at 900w@4ohm, 1200@2 and 1700@1
alpine t220 $50 shipped
50 watts RMS x 2 at 4 ohms
70 watts RMS x 2 at 2 ohms
140 watts RMS x 1 bridged output at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
MOSFET power supply
10-gauge power and ground leads recommended — wiring and hardware not included with amplifier
Tri-way capable (Tri-Way crossover required)
high-pass/low-pass (80 Hz) crossovers, 18 dB/octave
variable 0-12 dB bass boost at 50 Hz
20 Hz subsonic filter
speaker-level inputs
gold-plated power and speaker screw terminals
8-1/8"W x 2-7/16"H x 9-9/16"D
got a decent punch 500a2 with the variable x over.not bad shape and 2 of the speaker set screw holes are stripped.if you do bridged (+)left (-) right,you wont have a problem.its the other 2,which i have set screws.once their in they would be fine.i'll get some pics in the am.the comes with end caps too.$80 shipped
*******these need to go quick,so offer up!!************
alpine t220 50 x2 $60 shipped.real nice shape and a strong little amp.
is there a model number for the bolt series? wanna look up info quick...
Continuous Power / Channel Qty: 50 Watts x 2
Input Channel Qty: 2 channel(s)
Amplifier Output: 2-channel
Output Channel Qty: 2 channel(s)
High Level Inputs: Yes
Crossover: 2-way active crossover
Crossover Channel Qty: 2 channel(s)
Low Pass Frequencies: 40 - 400 Hz
High Pass Frequencies: 40 - 400 Hz
Bass Boost Frequency: 50 Hz
Bass Boost Gain: 0 to +6dB
Output Power / Total: 450 Watt
Amplifier Output Details:
* 75 Watt - 2 Ohm - 2 channel(s)
* 150 Watt - 4 Ohm - 1 channel(s)
i thought it was 250 i used it on an older JL W3 and it was plenty. pm me back let me know
destined2race
Already Being Used....
destined2race
Beatin Down Yo BLock
scarolinablazin
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
