WTB: Cheap amp
30 shipped for either 1 or 55 shipped for both.
around 250 watts at 4 ohms i do believe either 1
I have a DUAL amp..
rated at 580w at 4ohms bridged. I could do 50$ shipped, it's in great condition, and hardley used at all.
I also have a PA300d for 150$ shipped, which is rated at 900w@4ohm, 1200@2 and 1700@1
alpine t220 $50 shipped
50 watts RMS x 2 at 4 ohms
70 watts RMS x 2 at 2 ohms
140 watts RMS x 1 bridged output at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
MOSFET power supply
10-gauge power and ground leads recommended — wiring and hardware not included with amplifier
Tri-way capable (Tri-Way crossover required)
high-pass/low-pass (80 Hz) crossovers, 18 dB/octave
variable 0-12 dB bass boost at 50 Hz
20 Hz subsonic filter
speaker-level inputs
gold-plated power and speaker screw terminals
8-1/8"W x 2-7/16"H x 9-9/16"D
got a decent punch 500a2 with the variable x over.not bad shape and 2 of the speaker set screw holes are stripped.if you do bridged (+)left (-) right,you wont have a problem.its the other 2,which i have set screws.once their in they would be fine.i'll get some pics in the am.the comes with end caps too.$80 shipped
*******these need to go quick,so offer up!!************
alpine t220 50 x2 $60 shipped.real nice shape and a strong little amp.
is there a model number for the bolt series? wanna look up info quick...
Continuous Power / Channel Qty: 50 Watts x 2
Input Channel Qty: 2 channel(s)
Amplifier Output: 2-channel
Output Channel Qty: 2 channel(s)
High Level Inputs: Yes
Crossover: 2-way active crossover
Crossover Channel Qty: 2 channel(s)
Low Pass Frequencies: 40 - 400 Hz
High Pass Frequencies: 40 - 400 Hz
Bass Boost Frequency: 50 Hz
Bass Boost Gain: 0 to +6dB
Output Power / Total: 450 Watt
Amplifier Output Details:
* 75 Watt - 2 Ohm - 2 channel(s)
* 150 Watt - 4 Ohm - 1 channel(s)
i thought it was 250 i used it on an older JL W3 and it was plenty. pm me back let me know
destined2race
Already Being Used....
destined2race
Beatin Down Yo BLock
scarolinablazin
