WTB 500 or more @4 ohm Amplifier
JayRich
Looking for a good and efficient amp that would put out at least 500 clean watts at 4 ohms for my girlfriends dual 2 ohm 12 Oz audio matrix elite.
P.S. im looking for the power at 4 ohms rather than 1 to minimize the strain on her stock electrical system
175 watts RMS x 2 at 4 ohms
350 watts RMS x 2 at 2 ohms
700 watts RMS x 1 at 4 ohms in bridged mode
stereo or bridged mono output
Tri-way capable (Tri-Way crossover required)
50-210 Hz high-pass/low-pass crossovers, 12 dB/octave
wired remote control included for fingertip control of Punch Bass (boosts bass 0-18 dB, centered at 45 Hz)
MOSFET power supply and output devices
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
*****•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
speaker- and preamp-level inputs
8-gauge power and ground connectors
60-amp fuse and fuse holder required for installation
dimensions: 18-3/8"W (14-7/8" without endcaps) x 2-7/16"H x 9-7/8"
I have a ppi pcx 1250 for sale.. Rated at 12 volts 250 x 1 @ 4 and 500x1@ 2. Not only are they under rated, but will put out alot more than rated power at 14.4 volts.. Built like tanks too! 150 shipped!
JayRich
JayRich
Richmond, VA
gotdatwang
