Wtb 250w @ 4 ohm
alpine v12 t407
Road tested and time proven, V-12 amplifiers with their "no shut down" design keep playing when you need them the most. The Audio Quality MOSFETS and Subsonic Filter restore power and produce killer, tight crisp bass. They're also Bass Engine Ready meaning they can handle the juiced signal from an Alpine Bass Engine Equipped head unit.
* 2/1 Channel Operation
* Adjustable Crossover (LP)
* Auto Overcurrent Protection
* Bass EQ Circuit
* Bass Engine Ready
* DC Straight Design
* DC-DC PWM Power Supply
* Discrete Pre-Amp Stage
* Gold Plated RCA Input Connectors
* Input Mode Selector Switch
* MOSFET Final Outputs
* MOSFET Power Supply
* MultiMode
* Noise Elimination Coil
* One side Terminal Layout
* Phase Selector
* STAR Circuitry
* Solid Copper Bus Bars
* Speaker Level Inputs
* Subsonic Filter
* Top Mounted LED Power Indicator
* 1-year SonicElectronix.com warranty
Specifications:
* Dividing Network : 50Hz-200Hz HP/LP (12dB/oct)
* Foot Print (WxHxD)in : 7-1/8O x 11O x 2-3/8O
* Foot Print (WxHxD)mm : 180mm x 280mm x 60mm
* Frequency Reponse : 10Hz - 50kHz (+0, - 1dB)
* Heat Sink (WxHxD)in : 7-1/8O x 10-1/4O x 2-3/8O
* Heat Sink (WxHxD)mm : 180mm x 260mm x 60mm
* Input Impedance : 10k ohm
* Input Sensitivity (for rated power) : 200mV ~ 4.0V
* Power Requirements : 14.4V DC (11V to 16V)
* Signal to Noise (S/N) : 100dBA (referenced to rated power)
* Slew Factor : greater than 5
* Speaker Impedance : 4 or 2 ohms(stereo), 4 ohms(bridged)
MAX Power (at 14.4V,EIAJ)
* Bridged 4 ohms : 400W x 1
* Per channel into 4 ohms : 140W x 2
RMS Power (at 12V,20Hz-20kHz)
* Bridged 4 ohms : 150W x 1 (0.3% THD)
* Per channel into 2 ohms : 75W x 2 (0.3% THD)
* Per channel into 4 ohms : 40W x 2 (0.08% THD)
RMS Power (at 14.4V,20Hz-20kHz)
* Bridged 4 ohms : 200W x 1 (0.3% THD)
* Per channel into 2 ohms : 100W x 2 (0.3% THD)
* Per channel into 4 ohms : 60W x 2 (0.08% THD)
its old school alpine v12 so underrated fused at 25amps
85 shipped ?
Infinity Ref. 1600a. 400rms@4 600w@2. Ran it at 1 for days on 2 Kicker L7's clamped it at 754w. 7/10 Cosm:10/10 functional. Missing one speaker terminal screw. 100 shipped
CerwinVega_Fan
Coolest Member
CerwinVega_Fan
Dallas,TX
CerwinVega_Fan
