wtb 12-15 inch subs
looks like you're gearing toward an SPL application, give me your email and i'll send u pics of the RE MX, with the right power (1500+) and box (properly ported), you will not be disappointed.
kylehockey10@charter.net
and yes im geared about 80/20 towards spl.. i have
1000@4
1500@2 and
1900@1, i would like to run at 1 ohm if possible
and as far as properly ported box, what kind of specs are we talkin?
Your power of 1900@1 ohm will be a perfect match, my MX is dual 2 ohms, wired in parallel will give u 1 ohm.
Specs and T/S parameters can be found here:
http://reaudio.com/specs.html#sp_mx
use winisd and input those # and you can play around with freq response to your liking and determine your box size and tuning frequency. The box I used was 2.0^ft tuned to ~ 32 hz, sound decently good with a nice low end. From what i know, higher tuning frequency = higher spl as most bass note is in the 40-60 hz region. Whatever sub u decide on, make sure you have a proper box as it contribute a lot to how the sub will sound, so ask around the forum.
pbnj22
pbnj22
Duluth MN
pbnj22
