Scoobydoo
POOPSIE McSQUIRTYSHORTS
This is from another forum, but I had to post it
HIS ORIGINAL POST:
MY RESPONSE:
HIS REPLY:
MY REPLY:
HIS ORIGINAL POST:
I've got 3 25 ohm speakers, they are suppose to be use in an intercom system but 25 ohms is too much for our stuff. Non-DOA.
BE WARNED !25! Twenty-Five Ohms! IF YOU HOOK THESE UP TO A LESSER Ohms SETUP YOU WILL BURN UP YOU AMP/REVICER!
I am not responsible if you blow or damage your equipment because you hooked these up to a 8 or anything less than 25 ohms setup.
$20 each, shipped.
$50 for all shipped.
MY RESPONSE:
it is the other way around, the lower the ohm rating the higher the resistance, a 25ohm speaker has less resistance and create less of a load on an amp than say a 4ohm speaker
25ohm speakers will work on basically anything, but you wouldnt want to give them more than maybe 5 watts of power, they aren't made for that and you will probably fry the voice coil
HIS REPLY:
Are you sure? We had these things hooked up to a 400 watt 8 ohm amp, and it burned the amp up after ~4 months. We finally bought a new amp/tuner the other day and tried these out and the 200 Watt 8 ohm amp wouldn't even give us static on these things.
MY REPLY:
I am 100% positive.
With the amp you describe:
400 watts @ 8ohm
200 watts @ 16ohm
100 watts @ 32ohm
Half the resistance, half the power, double the resistance, double the power.
So you were probably giving that speaker about 150 watts and like you said it was made for an intercom and for about 5 watts, playing midrange voice frequencies.
My guess is you burnt up the speakers, not the amp
