my box has two seperate terminal cups for the wiring and my amp is a mono block. correct me if im wrong but to get it to be a 2 ohm load i should put the pos from the amp to both cups and same for the neg's...then hook up the inside as normal. this would give me my 2 ohm load right? by the way i'm running 2 12" perfects off a kicker kx600.1 if u wanted to know. I just wanted to make sure that was correct
