Would these Dual 12" Subs work with a car amp that I have?
Why do you say that?
A lot of inflated wattage amps are on the market right now that don't match their claimed power on the cardboard boxes they come in. Therefore, we have someone in particular here bigblank69 who has been testing a lot of amps lately and providing TRUE wattage from them.
Do you think a Kenwood branded AMP could do this?
like i said that amp is fine for those subs but if u wanta up grade amp or subs come back and well advise u on better subs and amp that does rated.. even my ppi amo in sig tested over 1100rms @ 1 ohm $165
Thanks for all the advice guys!!! One more question!
Is there anything I need to do to make sure my car has enough power to power the amplifier? I have a 2005 Acura MDX.
Looks like you have a 130A stock alternator which is good size. Just make sure you're using adequate power wire -- quality 4 awg is what you should be using. And make sure you're making good connections at every point. The ground side is just as important as the (+) side. Find a piece of structural metal, sand the paint off, make a good, clean connection.
Find a gain setting tutorial to follow -- there's one at the12volt.com called the ADD method that's simple and effective. I think it's in the stickies here too.
GenWatsonHV
GenWatsonHV
Castle Rock, CO
n2audio
