GenWatsonHV
I have two 12" Infinity Reference 1262W Subwoofers installed into a sealed box. The subs are currently set up to run in series. I can also run them in parallel. These are Dual-Voice Coil subs.
Specs for the Infinity Reference 1262W Subwoofer (Per Sub)
Type 12" (300mm) Dual-Voice-Coil Subwoofer
Power Handling: (Continuous/Peak) 100W-300W/1200W
Impedance: 2 or 8 Ohms
Audio Specifications
Sensitivity: 96 dB
Frequency Response: 23Hz - 400Hz
Cone Material: Polypropylene
Surround Material: Rubber
I also have a Kenwood KAC-9105D car amplifier.
Specs:
Mono Subwoofer Amp
500 watts RMS x 1 at 4 ohms (900 watts x 1 at 2 ohms)
1-ohm stable (output regulated to 900 watts)
Peak Power Output (Watts x Channels) 1800 x 1
Input Voltage 14.4v
Best Frequency Response 10-200 Hz
THD at Rated RMS Power 1%
Signal to Noise Ratio 100 dB
Features
Amplifier Class D
Low-Pass Crossover Frequency 50-200 Hz
Low-Pass Slope (dB/octave) 24 dB/oct
Bass Boost 0-18 dB
Bass Boost Frequency 40 Hz
Fan Cooled Yes
Fuse Rating 90
Speaker Level Inputs Harness
Preamp Outputs 1 pair
My question is, do you think that this amplifier would provide enough power to the two subwoofers? Optimally? I think the amp might not have enough power for what I have. Also, I'd like to put these in my 2005 Acura MDX. Any advice would be greatly appreciated!!!
Thanks!!!
Sensitivity: 96 dB
Specs:
Mono Subwoofer Amp
Input Voltage 14.4v
Features
Amplifier Class D
Bass Boost 0-18 dB
Fan Cooled Yes
Fuse Rating 90
Thanks!!!
