Would it be the same SQL??
azzkikr
Ok, I have a 12" kicker L5 in a 2.5cu.ft ported box tuned to 35hz and I am looking for a system of the same loudness. I would get another kicker but the box is too big and I don't want to give up how loud it would be. I have been looking around and like the sound splinter rl-p's. My question is, will 2 12" rl-p's be at least as loud as my kicker setup is? The box for them would be 1 cu.ft chambers for each sub. To start off, I will only be putting about 350 rms to each off of my xenon 600.1 (bench 700). I would wire them to 1 ohm. Any suggestions would be appreciated. THANKS
Only someone with experience with both can answer the question. Good luck with THAT little situation. =p
However, given box sizes and power, I'd say no. The kicker is in a very nice box for a 12, and tuned for SQL, with emphasis on the L. If 2.5 to 3 cubes is all you have, you'd be better off with a single 12 (again) ported. A pair of tens might also do you well.
azzkikr
azzkikr
Batesville,IN
Raven
BP1Fanatic
BP1Fanatic
