Would a Fi Q do OK with 600 watts?
As the title says, until I can upgrade to a bigger amp in a month or two? I have an Alpine MRD-M605, and I could send 600 clean watts at a Q until I upgrade to a new amp...
Thanks guys.
Unless you're planning to upgrade the amp soon, I'd go for an SSD with copper coils.
Will work fine, but if you're sticking to that amp for a while, I think the SSD might be a better choice
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Some people don't read, I guess?
I read it, I just know plans don't always work out so hot. I would personally just wait until you get the new amp. There will still be plenty of Qs around in "a month or two". I see no sense in going this route unless you're getting a really good deal on a used Q
Actually, I might even just wait for the new Mag and then you wouldn't even have to buy the new amp. Just my two cents
As soon as my tax return check comes, the amp will be upgraded. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Direct deposit ftw! If you're buying from Fi, you might as well just wait and order it when you order your amp. Change everything out at once. If you're buying from someone around here, then go for it.
ls2poweredgoat
Womanizer
ls2poweredgoat
Port St. Lucie FL
Hintzyboy
