Worth refinishing old school PG distro block?
Sleeklsc
I have an old Phoenix gold distro block that I used for a install 15 or so years ago. Over the years the finish started chipping (and then rusting), Is this piece worth refinishing? Everything is in good condition with the exception of the case and buildup up dust and such...
So is it worth putting in the time? I'd just end up selling it either way but figured I might get a little more if I clean it up a bit.
Looks like some sort of on off switch along with good and bad fuse indicators....but yea that circuit looks more complex than those 2 things...who knows I'm no circuit designer
btw, id be interested in buying.. pm me a price as is!
I haven't really thought of a price. Besides, all I have to compare it to is one or two similar units in original condition on ebay. It's a unique piece so I don't want to just give it away but do understand that it needs some makeup. Let me think about it.
why does a disto block need any kind of uh computer circuits??
I honestly don't even know. Trey knows just about as much as I do about it. All I remember doing is wiring it up like a regular distro and
hooking up the other terminal to ground. It has been so long since I've used it. I might just go test it again if I have some agu's in the tool box. Meh, wire will do.
The switch is to turn it on/off, it'll work either way as a distro block. Turning it on activates the leds and the RJ input. Leds are agu fuse status (Red=Blown, Green=Good) and I have no idea what the RJ 11/45(?) does. Smaller terminal off to the side is for ground.
She's filthy, time to give her a gentle cleaning.
Well haven't done much the last couple weeks. Shortly after the last group of pictures I polished the clear cover, cleaned the board, realigned the terminals and did the bulk of the prep work. Had a buyer but he didn't want to spend a couple extra bucks to help cover shipping so that motivated me to get it into paint. Today I did a quick pre-paint sand job and gave it a couple coats of primer until I can figure out which color I want to go with. I want something that'll look different but not tacky.
Just a loose fitting to see if white would look good.
Did some stuff today. Bought some black hammered paint and layed down a few coats. I had some time to kill between each coat so I decided to polish up the terminals. I wasn't able to get in certain areas so I ended up removing them. They were definitely in need of it, that's for sure. Didn't realize just how tarnished they had gotten over the years.
Before
This is when I decided to just polish them off the board
All done
Deff not going to hear much of a difference of the 4 ch amplifiers unless you are going to 100 rms per ch. With 10 watts, its just not worth the...
570
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
Absolutely not!!! Acetone eats everything it touches other than metal that is.. there is a reason it comes in metal containers with metal caps...
949
Sleeklsc
Sleeklsc
Papermaker85
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
