Woot AQ
with the 2nd amp a 150 should be possible. NICE daily set up with 1 or 2 amps though, enjoy...
thanks. Ill post some videos of my system when its done in 2 weeks //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
good luck man.....sounds like you will be whamming....
i can't wait until I can order mine...........
-Jordan
yea me to. I mean you cant beat the price and sound. Iv always head good things from aq and when ever u call or email them you always get the owner dj and hes very smart. He even whent though the hassle to design my box for them. Great guy!
Yea i just ordered my 2 15in hdc315 subs today! Im building a big box at 8.5cb feet @ 40hz after all displacements. Im also gething aq 2200D amp when they get it. Though all of it in my blazer. Its going to slap!
//content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif//content.invisioncic.com/y282845/emoticons/offwall.gif.29a91b9b265d47af4b8e33fc5b558d18.gif//content.invisioncic.com/y282845/emoticons/veryexcited.gif.c26a15f316d23068607f36ddacd7a7ab.gif:veryexci://content.invisioncic.com/y282845/emoticons/veryexcited.gif.c26a15f316d23068607f36ddacd7a7ab.gif//content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif
yea im thinking of geting 2 aq 2200D's when there not back ordered. So ill run each sub at 1 ohm 2200rms each. thats alot of power in a blazer
Well you can't do both of those. If you bought Dual 1 subs, they will wire to 1 ohm together, and let you get 1100 or so to each moofa. However, to run them each on their own 2200, you would need Dual 2 subs to wire each one to 1 ohm, or together to 2 ohm.
If you wire a pair of Dual 1s together on a pair of 2200s, each one would be running at 0.5 ohm. It should be fine for the amps, but it will be even more of a strain on your electrical. Same thing for a pair of Dual 2s on a single 2200 - wire to 0.5 ohm and strain your electrical. Or wire to 2 ohm and get around 600 watts per woofer.
So what coils did you order?
1ohm VC
so if i get one amp for now they will be done like that
damm im retarted. i can always get a different reone for them when i get the money for the 2 amp
Sounds like your only option to me; quite possibly one of the best too anyway.
roflmao. I wann make shere i dont clip those bad boys on this amp it has alot of power to offer. Got to go get a dmm. Btw i set the dmm on volts right. and wheres that damm calculator i need to figer out where i should put my gains at
MasterOfAllBass
Team Minnesota's Loudest
MasterOfAllBass
Minnesota
MasterOfAllBass
