Woot AQ
MasterOfAllBass
Team Minnesota's Loudest
Yea i just ordered my 2 15in hdc315 subs today! Im building a big box at 8.5cb feet @ 40hz after all displacements. Im also gething aq 2200D amp when they get it. Though all of it in my blazer. Its going to slap!
//content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif//content.invisioncic.com/y282845/emoticons/offwall.gif.29a91b9b265d47af4b8e33fc5b558d18.gif//content.invisioncic.com/y282845/emoticons/veryexcited.gif.c26a15f316d23068607f36ddacd7a7ab.gif:veryexci://content.invisioncic.com/y282845/emoticons/veryexcited.gif.c26a15f316d23068607f36ddacd7a7ab.gif//content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif
Need a box built? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
im building my own box,
but how much would it cost u to built it though.
SUBWOOFER CUTOUT 14.07 Inch
Build your box with the following EXTERNAL dimensions:
Width=37.5 Depth=24' Height=24.75 (double layer the top/baffle of the box)
Your box will have the following INTERIOR dimensions:
Width=36' Depth=22,5' Height=22.5'
Your subs will fire up and the port fires to the rear. Center the subs between the port walls and the ends of the box . Center subs front to back of the box.
Your port will be 6' wide, 22.5' tall and 16' deep measured from the outside face of the box, Your port walls will also serve as bracing.
Center your port in the middle of the box firing to the rear
Miter the inside corners of the box and the port opening
box is 8.5 cubes net after displacements and tuned to 40hz
MasterOfAllBass
MasterOfAllBass
Minnesota
MasterOfAllBass
