Wood?...1/4 inch mdf cedar used for closets?
Lonnie
6'6 White Giant
Well yea I found 7' x 8' sheets of cedar at lowes that they say is MDF boards. They are a 1/4 inch thick and are used for closet lining and are $29 a board.
Is this the right wood? Its supposed to be 2/4 inch right? So can I just make the box and double up on the wood by gluing another sheet on each sheet? Basically a box within a box. Do I use the same wood/double up concept for the inner areas? Like where the port walls are or w.e their normally called.
Im needing a new box...currently have a REALLY old pre-fab and it is on its last legs. Its untelling how many leaks it has in it...
Im sure their are probably an answer to each of my questions on these forums. Really wouldnt know what to search it as though...
Usually sheets come in 4'x8' sheets. And i have never ever heard of cedar mdf.. If you could take a pic of it that would be much easier to tell. But 1/4 inch isnt going to really work. You need at least 1/2 inch and you could double that up. Or just 1 single layer of 3/4 inch. I would just go with the 3/4 it would be cheaper than doing 2 layers of half inch. Hope depot def has 3/4 its about 27$ a sheet here in ohio
Not too mention simpler due to half the cuts //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.. $33 a sheet here
Closest home depot is like 80 miles away -.-
Used to have one, but lowes ran em outta business.
Lol at "2/4". Lowest terms fail. There is no such thing as 2/4.
You sir are an idiot for calling me one and then proving my point. 2/4 is indeed 1/2 which is why 2/4 doesn't exist.... dumbass
Hey cunt-****, how does 2/4 "not exist"? Does 4/8 "not exist" either?...how about 1mil/2mil?
Lesson: it's still a number, just not reduced completely.
Lonnie
6'6 White Giant
Lonnie
Paducah, Kentucky
RAM_Designs
