Witch amp should i go with?
I found a Boss Audio R1100M for only 50$ seems kind of cheap for an amp.. it is monoblockMOSFET Monoblock Power Amplifier
Remote Subwoofer Level Control Included
1000W x 1 Max Power
250W x 1 RMS Power
Good deal? Or is this a cheap amp that will blow?
Stay away from that amp..its not good quality, and very over rated/waste of your money
I understand it is expensive, but i'm not trying to win any competitions, and the friends I hang out with don't know much about systems. So anything with a loud nice sounding bass would be good for me.
The hifonics amp you posted is only 100watts, is that enough power? I offered him a deal.
Thats what all you guys think when you see 100 watts/1000watts posted..you think that thats all it can do maxed,or thats what the power rating is on the amp.Not true, especially old school cheater amps,and this is a cheater amp..Its 100 watts min@4ohms @11.6v even under rated back then, but what you guys dont know, is what is a cheater,and what isnt.I have one of these exact amps in my collection, and have ran all the series of Hifonics up to x series,and these are the best ever made as well as the viii series by Hfonics.If its not enough power to run your subs, I would have recommended it.Ill put money on it, that your subs wont be able to handle the power that amp puts out @50%gain
Autotek 7050 BTS Power Amplifier Audio Punch Precision ZED Amp Old School | eBay
You see this little 44 watt amp??This is another little Cheater that will Slamm a pair of 600 rms 12s/10s or a 15 @2ohms hard and heavy at 12oclock position on the gain..Its a little BA,,I know, because I own 4 of them,and have run them.This amp will blow that Kicker/SStream,PPI mentioned,cleanly in the dirt,,It would be close with the vulcan
The last ebay you posted, looks like 12 gage wire. I got 4 gauge, i been looking all over for a piece that i can put 4 gauge wire in and than y connect it to the amp. But o reillys, best buy, menards, sears, nobody has them.. well not at the right size.
Its 8 ga power and ground wire,speaker wire is 12 ga on the amp..I can send you a copy of the wiring connecting for either amp..or i can give you a call/text with pics of how to wire it up..no problem:santa:..just dont pass up an excellent amp for the money
They look so old that I wouldn't know how to hook em up. My friend says put the gain 1/8 of the way to the right or at 75% and that is deal for any amp.
I think your friend may need to do some reading up on setting gains on amps..not all amps are equal as well as any component,even the same made amp, all are/can be different.Im not trying to be hateful to your friend,its just facts
i have the original specs booklet for the VII/VIII Hfonics amps, and Ive used the Autoteks for years,and know how to wire them.I still have my first amp from 1990 that bought from Autotek, as well as some of the Hifonics from 89,So i can help you out there, no problem
darron016
darron016
minneapolis, mn
audiobaun
