wiring ?
outsideshot23
Been a long *** day. im pissed off. (thats another story). my head is tired of thinking. I got 4 subs. dual 1 ohm coils. 4 d9s. I was thinking ohm loads. I have all of the voice coils wired to bolts on the box. so 4 bolts per sub. 2 pos 2 neg. Was thinking instead of running little jumper wires on the box from bolt to bolt to bridge the subs could i not just run 2 long runs of each back to the amp sincer it has 2 inputs and it would essentuioally bridge for me? make sense? and what ohm load would it be? .5? then how would i get .25 out of it. These bolts in the box makes it more confusing
If you wire each sub straight to each amp they'll be at 0.5ohm. The only other thing you can do is wire two subs in parallel to 0.25ohm then strap a pair of amps to them at 0.125ohm each.
You can't get 0.25ohm per amp with 4 amps and 4 dual 1ohm subs. Need dual 2s for that.
yep.. i might have 2s.. they are at a buddys house who ordered a pallet i havent poicked them up yet. he was the one who suggested 1 ohm for daily and .25 for burps so im sure they are 2's.. thats what i was thinking i would have to strap the amps.. ****. .25 strapped is low
outsideshot23
outsideshot23
OKC
outsideshot23
BP1Fanatic
BP1Fanatic
