Wiring
Lucid15
Always open to trades!
So i just received my 2 Soundstream T4-12's.... jus tried wiring them to my Kicker 750.1 rated at 911 RMS.... no luck.. i tried wiring them both down to 2ohms... then tried one at 4 ohms... not even a sound. Am i doing something wrong?
Nothing has changed... about a week ago i blew my two Kicker CVR's.... These soundstreams are both dual 1 ohm voice coils.. i want them both wired down to 2ohms at the amp. Sub bass controller is at full and RCA's are in.
To get 2 ohms on your current amp with these soundstreams...just run the positive terminal of the amp to the first subs positive terminal...then from that first subs negative terminal, run a speaker wire to the second subs positive terminal, and then from that subs negative go back to the amp's negative terminal and that'll get you 2 ohms... (This is what someone said from another forum... is this incorrect?
Lucid15
Lucid15
Portland,OR
Lucid15
