HardofWhoring
My first thread here, and just signed up. I have spent some time searching the interenet, youtube, and found here. Got a couple hours in, and thought its time to ask, hoping for some help. (question is the last paragraph).
I had my stereo system installed by a shop a couple years ago, and keep discovering problems that if I knew I could, I would probably sue them to get more than refund.
They GLUED in the tweeters from my component speakers.
They cut the butt connectors off the tweeter wires so they could use caps.
They GLUED the bass knob on the dash.
They capped together three pieces of wires for my subwoofers for a 6ft length of wire.
They drilled screws through the back of the cab to mount the subwoofer boxes
They used two tiny self tapping screws, through the lug and not the lug hole to individually mount each amplifier (I have a problem thinking these self-tapping screws are big enough to ground well).
They didn't mount the amplifier or the distribution block
They mounted the crossovers in the door, (and now they have rust on the screw terminals).
They drilled holes through the cover of the crossover instead of taking 2 seconds to open them and using the mounting holes that are built in, (then covered the hole in the cover with electrical tape).
They daisy chained the remote wires on the two amps.
I didn't discover these all right away, and there were probably a few more that I am forgetting. I am trying to not only fix it all, but add a third amp, with a better than factory pair of rear channel speakers, bi-amp my components, added a larger alternator, have a fan to add, improve and solder all connections, adding frequency filters, and going to add a new headunit to run 3 RCA outputs, (components, rears, and subs). This has been a lot of money spent, and a lot to learn so far FOR ME.
Don't think I need to get into details about the pieces I have, and think I have most everything down. I read my HU says to add no more than .4a to the remote wire, and am certain everything I want to run will be more than that. I am not sure what my amps are, but I am going to run a relay, and not sure if the "relay wiring" is correct.
I am going to run an SPDT relay, but have never used one before, and all the videos and info make it seem easy. The remote turn on lead is easy (16awg wire back to the HU). I was going to run the 87 tab with 12awg wire to a 5 post busbar, and run each remote wire off a separate post with ring terminals and 16awg. The fan to a separate post, and ground the fan and relay with separate wires and ring terminals on to a factory bolt ground under the seat. Last, is the 12 volts. I will have both (fused 3 way power, and non fused 3 way ground) distribution blocks with a couple feet. If so far this sounds like a good way of doing it, I am really uncertain what would be the best way for me to run post 30 to 12 volts. I am not sure if I would try to run that all the way back under the hood and run that to the power post at the fuse block. If I should just use a ring terminal and add it over one of the MANL fuses at the distribution block, If I should use an add a circuit to the panel under the dash and run a new 16 awg wire back to the relay... ????? Is there any reason I should or shouldn't do it any of these ways, or is there some really common thing people do that I should have found the answer to by now? Thank you or any help.
