KyleBechtold
Quit reading this
Alright I think i got this down but not %100
1.) Positive from front batt to second batt
2.) 2 Fuses 18" or closer from the batteries one on each side
3.) Ground the negative from the second battery as close as possible on a good ground..
4.) positive from 2nd batt to amp with fuse close to the battery..
Did i miss anything? also would it be better to run the negative from 2nd to chassis or 1st battery?
for the fuses between batts should i use 300 anl fuses?
