wiring up 2nd battery..
KyleBechtold
Quit reading this
Alright I think i got this down but not %100
1.) Positive from front batt to second batt
2.) 2 Fuses 18" or closer from the batteries one on each side
3.) Ground the negative from the second battery as close as possible on a good ground..
4.) positive from 2nd batt to amp with fuse close to the battery..
Did i miss anything? also would it be better to run the negative from 2nd to chassis or 1st battery?
for the fuses between batts should i use 300 anl fuses?
You 're correct, i would use as small of a fuse as my amp would allow. But 300 will work, if your wire is rated for 300. Chasis ground should be fine for second battery.
are the batteries in parallel with out an isolator? if so, the alt will charge them both. it will be fine.
btw, i use 2x 300a for my battery wire (front - rear)
parallel by the neg-neg and pos - pos.. then yes.. no i didn't get an isolator as i won't be running this while my car is off...
KyleBechtold
Quit reading this
KyleBechtold
Tampa, Florida
iamamp3pimp
