Wiring two subs to mono amp...help?
How do I safely "wire both wires together"? That would be essentially connecting three wires together.
Also I have spades. If I wrap one 12 gauge around a spade of another 12 gauge and stick that into the terminal would that work?
yea... but I can't go from one sub to another to the amp. pics are hard to take lol.
Basically the terminal is a cylinder thing. There's a hole on the top and 2 on the side. One 12 gauge wire fits through the side holes and I screw the cap down on the wire to hold it in place. How would I get two 12 gauge wires to fit in there? Or can I crimp a spade onto one 12 gauge, wrap the other 12 gauge around the spade and stick it in?
Also I tried to wire it as a series, like a circle, and only one sub works... don't think it works
My amp is alpine... only one pos and neg term. and yea it's 2 ohm stable
That's probably b/c you did it wrong. Just do it like I said, it will work. Unless your other sub is blown.
Georgy
Georgy
Bay Area, California
Georgy
