Wiring two subs, 2 channel
Lurius
Ok, I am pretty new to car audio, so bear with me please!
I am about to wire up two JL 10w3v2 d2's.. I want to run it with two channels(I enjoy stereo bass, I dont like mono much). I am looking at the PDF file for these subs and there are two methods listed for wiring the subs "Voice coils in series" and "Voice coils in Parallel".
I do not wire these subs together in any way to do this with 2 channels, do I? So I would wire the subs seperate of each other is what I am thinking, correct me if I am wrong though.
What are parallel and in series though? What would be the difference in sound, etc?
Thanks a ton, I think I have the wiring part down, I just dont know which method to choose yet!
Thanks,
Lurius
>>Here's>Here
If you are going to wire them to be driven by separate amp channels then your options are either the 1 Ohm (parallel) or 4 Ohm (series) choice. As the majority of amps are NOT stable at 1 Ohm in stereo (some exceptions exist but the majority of amps are not) you'll need to use the 4 ohm option. With that in mind look for an amp that does adequate power per channel @ 4 ohms and you'll be gold! //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
Im using an alpine t757 which is supposed to be stable at 1ohm stereo and 2 ohm mono, but its one of points that alpine denies but others say it is stable, so ill risk it and have it tested soon before I really push it.
I have one more question, if I run two 2ohm subs with 1 ohm load, one on each channel, will this be a .5 ohm load on the amp, or will it be 1ohm load on the amp?
Thanks again for the fast reply!
Lurius
Would this make the load on the amp .5ohm?
I am actually thinking of going with the 4ohm wiring.. I think if I run the two subs at 4ohm then it would be 2ohm load on the amp, correct me if im wrong though.
-Lurius
you're making it too complicated.
If you wire your subs' coils in parallel on each channel that's 1 ohm stereo.
The other option would be to bridge the amp and wire the subs together series/parallel for a 2 ohm MONO load on the amp, which has the same effect on the amp as 1 ohm stereo.
The only other possible scenario would be - amp bridged, all 4 coils parallel - that would produce a 1/2 ohm MONO load on the amp and it shouldn't even turn on if you try that.
Ok, thanks a lot lol, the manuals included with the amp and subs are not nearly enough knowledge to help a first time installer, im glad I can ask here =)
Thanks again,
Lurius
Lurius
Lurius
Arlington, Texas
Lurius
